28 Feb 2024 08:57 AM
My mini box turns off after 10 mins,we've rebooted everything several times and on Sunday,we rebooted the booster and box lasted a hour,now back to lasting 10 mins then off again!
28 Feb 2024 09:12 AM
Hi @Cheako72
Is the mini box getting hot?
They do run quite warm but not so hot that you cannot easily bear your hand on them.
Also is it well ventilated and not totally enclosed?
You could try Reset Settings in the mini box hidden menu.
After the Reset you will have to re pair your mini Bluetooth remote If you use one.
If you cannot switch the mini box on with the remote after the Reset press the Standby button (Amber led) on the front of the mini box.
Make sure that you are pointing the remote at the mini box when you press 1 & 3 together.
28 Feb 2024 09:21 AM
Thanks mate tried all that and box ain't getting hot,just been on phone a new one is getting sent,
thanks for yer time and answer mate
