20 Jul 2023 07:50 PM
Hi there my internet says I have internet is connected but it not connected
20 Jul 2023 08:02 PM
If this is your main Q box @xxjakexxopsxx
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
