17 Jan 2024 10:39 AM
Why can't I change my Netflix account to my Sky account on any other device than the main Sky box
17 Jan 2024 12:24 PM
@Heather75 wrote:Why can't I change my Netflix account to my Sky account on any other device than the main Sky box
You can. You just need to log in to the Netflix app on your other device with the same username and password that you used to set up Netflix on your Sky box.
Which Netflix tier do you subscribe to? Is it the basic service with ads?
05 May 2024 07:06 PM
I have this problem too! How do I retrieve the sign in details I used for Netflix on my Sky box??
05 May 2024 07:38 PM - last edited: 05 May 2024 07:39 PM
hi @ALONE+OAK
You can check which email by y going into the app then Left arrow to bring the Side menu
Then arrow down to go to 'Get Help' & press enter/select
This will show the email account you used
You can't find out what your password is but you can go to Netflix password reset on a browser on another device to reset it (If you do reset it, you will need to use the new one on the SKY Q box as well, of course)
