Discussion topic: Sky go doesn’t work when Xbox connected to a monitor instead of a tv
This message was authored by damienshevlin This message was authored by: damienshevlin
I connect my Xbox to a monitor instead of a tv and when this is the case Sky go won't work on the monitor. When I connect to a tv it works just fine. Is there any reason for this? It used to work I think at some stage. The monitor is a Lenovo G27c-10.
Anyone any ideas or help?
This message was authored by Annie+UK This message was authored by: Annie+UK
Re: Sky go doesn’t work when Xbox connected to a monitor instead of a tv
HDCP? TVs have HDCP and only some monitors do
damienshevlin
Would it not come up with a warning to say this is the case?
Not necessarily, no.  As @Annie+UK indicates, it's the most likely reason (Q does require HDCP) and this page would seem to indicate that particularly monitor doesn't have it, which would seem to be a rather odd choice by Lenovo.
damienshevlin
Thanks for that. I can understand if I was connecting my Q box but seems odd when running through Xbox. Any idea if there could be a work around?
Xbox still has HDCP it needs to for DVD/Bluray etc... it looks like any video outputting app can take advantage of the extra security HDCP provides
I would think that the majority of xboxes are connected to a TV and not a monitor
damienshevlin
If I tried playing a dvd/blu ray through monitor would there be problems too?
@damienshevlin
Probably, yes: commercial optical disks will almost always require HDCP as a fundamental anti-piracy measure.
There is a very big probability that you'll have a problem, anything that requires HDCP will fail if the display does not have HDCP, this is to prevent the pirating of copy protected content
On average, new discussions are replied to by our users within 3.6 hours
