Discussion topic: Sky go doesn’t work when Xbox connected to a monitor instead of a tv
This message was authored by: damienshevlin
I connect my Xbox to a monitor instead of a tv and when this is the case Sky go won't work on the monitor. When I connect to a tv it works just fine. Is there any reason for this? It used to work I think at some stage. The monitor is a Lenovo G27c-10.
Anyone any ideas or help?
Re: Sky go doesn’t work when Xbox connected to a monitor instead of a tv
HDCP? TVs have HDCP and only some monitors do
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
Avatar for damienshevlin
Would it not come up with a warning to say this is the case?
Not necessarily, no.  As @Annie+UK indicates, it's the most likely reason (Q does require HDCP) and this page would seem to indicate that particularly monitor doesn't have it, which would seem to be a rather odd choice by Lenovo.
Thanks for that. I can understand if I was connecting my Q box but seems odd when running through Xbox. Any idea if there could be a work around?
Xbox still has HDCP it needs to for DVD/Bluray etc... it looks like any video outputting app can take advantage of the extra security HDCP provides
I would think that the majority of xboxes are connected to a TV and not a monitor
If I tried playing a dvd/blu ray through monitor would there be problems too?
@damienshevlin
Probably, yes: commercial optical disks will almost always require HDCP as a fundamental anti-piracy measure.
There is a very big probability that you'll have a problem, anything that requires HDCP will fail if the display does not have HDCP, this is to prevent the pirating of copy protected content
