Discussion topic: Sky device pin
This message was authored by Josh1996 This message was authored by: Josh1996
Sky device pin
I keep having the same issue. I download shows to watch on sky go app and it sometimes (not always) asks for a decice pin and everytime it says my pin is wrong. I have reset over 10 times and it still wont work. I have also tried downloading the shows on my actual box but it does not download them.
Re: Sky device pin
@Josh1996
If it is not connected to a Sky Q ox then it can be reset here:
https://www.sky.com/manage/tv/manage-devices/change-pin
As it might be that you are resetting the TV pin which is seperate to the Sky Go one.
This message was authored by Richard36 This message was authored by: Richard36
Re: Sky device pin
same problem
Re: Sky device pin
Same answer then.
On average, new discussions are replied to by our users within 3.6 hours
