20 Jan 2024 02:43 AM
Hi
Can someone help
Cant get my sky go to work on my mac [macbook pro 2016 os 12.7.2]
Have deleted the app and reinstalled as per advice
App loads and then says 'checking for updates' and then just hangs
Any advise would be appreciated
20 Jan 2024 05:35 AM
Posted by a Superuser, not a Sky employee. Find out moreTry a complete uninstall:
Uninstall the app
Launch the Finder, go to the Downloads folder and delete ‘SkyGoInstaller.’
In Finder, go to the Applications folder and delete Sky Go app
Remove Sky Go files
In the Finder select Go to folder ... from the Go menu (or press c).
A dialog box should appear. Now copy and paste the following text into the box and press the return key: ~/Library/Application Support/
Select the Sky Go folder and delete it
Empty Recycling Bin
Reboot the Mac
Download and reinstall Sky Go
On average, new discussions are replied to by our users within 3.6 hours
