17 Nov 2023 02:43 PM
when we had sky fibre installed our alarm cant be monitored as it works on an annalogue connection, the alarm company suggested n analogue box and sk would provide one, is this the case
17 Nov 2023 02:53 PM - last edited: 17 Nov 2023 02:56 PM
There's no such thing any more: since September 5th 2023 all new broadband provisioning across the UK is without an analogue (PSTN) service. Your alarm company really should know this.
17 Nov 2023 04:04 PM
@Nickyc70 wrote:when we had sky fibre installed our alarm cant be monitored as it works on an annalogue connection, the alarm company suggested n analogue box and sk would provide one, is this the case
As @TimmyBGood says, you can't have an anlogue line when you switch to FTTP.
You can get Terminal Adapters that will allow you to connect the analogue line to the router but they may not necessarily work with an alarm system if it uses any special signalling.
To be honest, it's the alarm company that should sort it out because they should know that analogue lines are being phased out. My alarm company swapped out the analogue module in my alarm for an ethernet based one.
17 Nov 2023 04:22 PM
Posted by a Superuser, not a Sky employee. Find out more@Nickyc70 Most decent alrm providers will have systems that either utilise the 4G network or your home broadband, if your current provider is being hesitant in providing this to you as an upgrade I recommend you change provider.
