Discussion topic: drop line
This message was authored by loverboi This message was authored by: loverboi
drop line
is this safe for my drop line to be like this being pushed by branches and will it affect my connection or make the cable snap soon or later and advice and help  will be very appreciated:) 😞drop line.jpgdrop line.jpgdrop line 3.jpg
Re: drop line
@loverboi
Safe? Yes
Good for the line? No
I would recommend taking a look at Openreach's page on this and decide if you should report it to them
https://www.openreach.com/help-and-support/damage-health-and-safety
I am NOT a Sky Employee
loverboi
Re: drop line
@jamesn123 thanks for the quick reply and im worried as the branches are growing upwards and the line is sitting on them and pushing it higher and higher and im worried that it will where its cliped to house that the cable will be under so much tension that it will be snap and im left with no broadband 😞
Re: drop line
@loverboi
You are right, it may well damage it. Like I said, take a look at the site I linked and report it to Openreach.
Do you know whos property the trees are?
loverboi
Re: drop line
thanks sir 🙂 😞
Re: drop line
Unfortunately Openreach basically doesn't do proactive maintenance on individual domestic cables (and aren't required to do so by Ofcom): it's apparently more efficient to wait until things fail.
loverboi
Re: drop line
@TimmyBGoodthanks ahh yes i was  told that by asky when i got a call back as earlier when i rang they had issuse with computer thats why i had call back but i asked family to trim them but they refuse 😞 so im haveing to wait for the worse 😞
loverboi
Re: drop line
but i was threatened by family/the owner of the trees that i will get openreach to move the line away from trees and then i got threated by the saying that if openreach go mnear their trees they will cut the line as they say its on their trees and its their line not open=reaches but i have autisum and mild leaning difficulties and as well i feel un comthable what i can do as i dont feel okay with threats and with the threats what can i do if they try to damage the line/cut it in a childish way can i report it to openreach as criminal damage and report to sky and how long would it be if they did it to be reinstatedthanks any help/advice on what steps i can take and any help/advice  will be very appreciated:(
thank ken:) 😄 (would i have to contact sky to see what my options are as im registed with the accessibily team can i ask sky to see if they can move line but put myy own from pole or will that be classed as a new line from the cabnet 🙂 😄   )
