13 Dec 2023 10:47 AM
How do I find my WiFi password if I can't access my hub?? Will sky give me it if I call??
13 Dec 2023 11:01 AM
Posted by a Superuser, not a Sky employee. Find out more@Louise88 Sky can't give it to you but the details you need are on the label on the hub but of course you need physical access - it maybe on the bottom - if those do not work press and hold in the reset pin or button until the power led flashes then release and once the hub restarts the details on the hub will work.
