12
Discussion topic: Using Sky with Asus Router
This message was authored by candrews99 This message was authored by: candrews99
Hi all,
I currently have BT via VDSL2 (no fibre in my area yet). I am using an Asus RT-AC86u as my main router, connected via an EchoLife HG612 Openreach modem, and an RT-AX56u in AiMesh using Ethernet Backhaul. I am leaving BT on 26/02, and I would like to be able to setup my main router as soon as our connection starts.
I have done some reading, people say that PPPoE is only used in Ireland for Sky (I live in Northern Ireland), which is what I am currently using for BT, and I keep seeing mentions of DHCP Option 61. Can someone kindly give insight into what settings to apply, usernames and passwords to be used on the Asus router etc, things to look out for etc.
Thanks!
Chris.
This message was authored by cookiemonsteruk This message was authored by: cookiemonsteruk Answer
Re: Using Sky with Asus Router
@candrews99
That should work.  Check out a setting called client identifier (option 61 and enter
anything@skydsl|anything
The echolife may already have a vlan id tag of 101 if not its easy to set up on the asus
@candrews99
candrews99
, I Re: Using Sky with Asus Router
Thank you for your response. Had a quick look at the settings on the router last night, I see nothing for DHCP option, or class identifiers, I wonder if this is because I have Merlin running on it, or perhaps because I still have PPPoE selected as my WAN connection type (I don't want to change or break anything just yet).
As for the VLAN tag, a quick Google brought up plenty of videos on how to set this up, so this shouldn't be an issue when I have to set everything else up.
I've also read that people say you should leave your Sky router plugged in for a while, some say a couple of hours, others up to 10 days?! Others have also mentioned that Sky have cut their connection for using 3rd party equipment, surely this isn't the case in 2024?
Thanks again for all your help so far!
Chris.
@candrews99
Could you post a screen shot of you wan screen settings
candrews99
@cookiemonsteruk
Here you go, thanks again!
@candrews99
Pppoa needs changed to auto ip . This should bring up client identifier (option 61)
candrews99
@cookiemonsteruk
Thought as much... Won't change anything until I am setting the router up for use with Sky. Thanks again, hopefully there won't be any head scratching come the 26th 😅
@candrews99
You can freely change the drop down option & browse the settings without breaking anything as long as you dont hit apply.
I am NOT a Sky Employee
candrews99
@cookiemonsteruk
I'm back...
This is proving rather difficult. I have set WAN connection type to Automatic IP, option 61 field populated with "anything@skydsl|anything", WAN MTU is 1500 and DHCP query frequency is "normal mode".
IPv6 is set to native, nothing else changed under this menu.
Dual WAN is enabled, primary WAN set to Ethernet LAN (LAN port 1) and secondary WAN is set to WAN.
Finally, under the IPTV tab, ISP profile is set to "manual setting" and Internet VID is 101.
Unsure if I am supposed to connect cable from Echolife to WAN port on router or LAN port 1. Either which way, I get no connection. I've included photos of any of the settings I have altered, excuse the camera photos, no Internet connection 😅
I hope this is something glaringly obvious I am missing.
Thanks!
This message was authored by mae-3 This message was authored by: mae-3
@candrews99
Remove the VLAN setting of 101 on the Asus as this is built into the modem you are using to connect to the VDSL2 broadband line, leave the Asus router and modem off for half an hour then reconnect everything and it should work fine, hopefully.
Zen internet on G.fast (250Mbps down, 50Mbps up). SAT> IP (Apple 4K 2nd gen TV to LG C1 OLED UHD TV/Dolby Atmos Denon AVR, DacMagic Plus for Hi-Res audio), hosting own blog/forum (cluster), OPNsense & Zenarmor L4/L7 NGFW & DPI IDS/IPS, Asus ET12 Pro Tri-Band wifi, Linux, Gamer: Xbox Series X/i7 laptop, round-robin DNS over HTTPS, non-proprietary VoIP HD AMR-WB (G.722.2) and more... Beta tester Apple iOS/watchOS/tvOS/iPadOS/macOS.
candrews99
@mae-3
Thanks for your response at this time.
Should I also revert the settings under Dual WAN? I have to assume these settings are not needed or are incorrect anyway?
I have now switched everything off for half an hour, fingers crossed.
@candrews99
Yes, disable the dual WAN as well as only 1 WAN is set up for Sky.
candrews99
@mae-3
That has done it!! Absolute legend! Who would have thought it was that VLAN tag this whole time... Binned it, reset Dual WAN settings, didnt have the patience to wait half an hour, and away it went! Thank you so much!
