06 Sep 2023 11:09 AM
Hi all. Thinking about switching to Sky fibre but I have several dect phones using the current copper wire input. Does the new Sky Fibre router have a BT style socket so that I can plug in my dect base station? Anyone have experience of doing this? TIA
06 Sep 2023 11:52 AM
Posted by a Superuser, not a Sky employee. Find out moreYes, you will plug your dect phone ( base station), using the same cable into the back of the Sky router, instead of your current master socket.
I do the same, having moved to Sky Ultrafast + in the last month and it works fine, with clear calls.
06 Sep 2023 12:19 PM
Thank you - very helpful!
06 Sep 2023 01:21 PM
Just a further question.... do you still need a landline to make calls? Not sure whether VOIP uses landline of fibre connection. TIA
06 Sep 2023 01:25 PM - last edited: 06 Sep 2023 01:30 PM
VOIP is data (Voice Over Internet Protocol) and so is carried by whatever broadband is available: that could be ADSL/FTTC/G.fast on a copper circuit or FTTP on optical fibre. The concept of a 'landline' is becoming obsolete, but terrestrial broadband does require a physical data bearer cable of some kind.
