15 Nov 2023 03:27 PM
Hi I have Sky Q Broadband with a Sky Booster, problem is it keeps interfering with my Sonos speaker setup. Only issue is I have my Tado smart thermostatinternet bridge plugged into the booster via ethernet. My question is can I turn off the boosters WiFi output and leave the ethernet on for my Tado bridge? Both of my ethernet ports in the main router are being used and the booster is close enough to the boiler for the Tado to work. Hope this makes sense. Thanks
Phil
15 Nov 2023 03:30 PM
No: how would anything be reaching the booster from the Hub?
15 Nov 2023 03:36 PM
Thanks thats what I thought. Is there another device I can use that I can connect wirelessly to my router that has an ethernet port and doesn't affect anything else. Apparently Sonos systems don't like Sky Boosters. Cheers
Phil
16 Nov 2023 02:39 PM
Posted by a Superuser, not a Sky employee. Find out moreUse powerline or a WiFi to ethernet adapter
