01 Aug 2022 04:40 AM
Hi I just got a new mobile and it says weak security under my home wifi, it's saying my hub needs to be wap2 or wap3 and doesn't let me onto the internet although it's ticked to say it's connected, my other phone is accessing the internet fine? Any ideas how to change the router to wap3 or wap2 please
01 Aug 2022 06:07 AM
What router do you have? Is it the sky q router?
01 Aug 2022 06:12 AM
I have sky Q and yes the router is for that, I also have sky buddy and my new phone went to the home account which has some restrictions set for my teenage son, I've moved my phone to my own account and WiFi now seems ok and doesn't say weak anymore!
sky buddy has been a complete nightmare for many reasons so I assume it was that blocking my WiFi (though my son who it's intended to block gets through it seemelessly) thanks for your reply, I'll come back if this doesn't stay sorted. Kind regards
01 Aug 2022 08:48 AM - last edited: 01 Aug 2022 08:49 AM
Posted by a Superuser, not a Sky employee. Find out moreWPA2 or 3 rather than 'wap2 or wap3': WPA is Wi-Fi Protected Access.
A current Sky Hub should use WPA2-PSK by default: neither BT or Sky currently support WPA3 on their routers (the next versions undoubtedly will). Apple have decided, somewhat arbitrarily, that only WPA3 should be acceptable.
01 Aug 2022 08:53 AM
Thankyou, not sure if that was me all Bleary eyed as it was early or autocorrect 😂
Hopefully it's sorted out now, seems annoying apple choose what's best and messes with your ability to browse 🤷🏻♀️
03 Dec 2022 09:20 AM
I'm having exactly same difficulty; what did you do to solve it
29 Jun 2023 11:40 AM
I tried many solutions online , but finally solved it by restarting the Wi-Fi router and your iPhone before you connect to the Wi-Fi.
12 Dec 2023 11:10 PM
Apple only needs WPA2(AES) currently implemented or better, the warning message doesn't come up then. Apple is complaining about WPA2-TKIP, which is weak security and only the messenger that the router is set up incorrectly. This nonsense about Apple requiring WPA3 is just that.
13 Dec 2023 09:22 AM
Posted by a Superuser, not a Sky employee. Find out more@mae-3 the black Sky hubs all default to a setting labelled as WPA2-PSK (AES) but we get regular reports of Apple ios devices reporting hubs which are sunsequentally proved to be running the default setting as insecure. Very recently we have seen a rash of issues where devices have said the hub's were running WEP. My own ios devices have never reported any issues and are running the latest ios settings. However my devices are not new enough to support WPA3.
The messages seem to be superious but the reason why ios devices issue the warning in the first place is still live. I have seen similar posts on other isp's support forums so this is not an issue restricted to Sky hubs. The response I give is that if worried customers should check the setting on their hub themselves which can be done by opening the web interface or running Sky's service checker.
13 Dec 2023 09:26 AM
It may be a bug in older releases of iOS that has been fixed in the latest release issued yesterday or people setting up their routers in WPA2-TKIP by mistake.
13 Dec 2023 09:31 AM
Posted by a Superuser, not a Sky employee. Find out more@mae-3 could be who knows. Key thing is unless someone has changed the setting Sky hubs run a level of wifi security that is reasonably secure.
13 Dec 2023 09:41 AM
I think the key exchange in WPA2 (AES) may be suffering interference on the wireless band in these cases from neighbouring Wi-Fi systems when it is reported that the security is weak. But generally speaking, the packets of data passing around the wireless networks are generally safe for use currently.
13 Dec 2023 09:59 AM
I would highly recommend that those with this issue upgrade to Sky Max and set WPA3-T or even WPA3 for their security if all their devices support the standard. From my experimentation, these security settings will lower the chance of interference from neighbouring Wi-Fi systems.
