02 Apr 2024 01:58 PM
I had an OpenReach engineer come out the other day to fix my broadband. They said they did it. But I still have the same problem.
What do I do? I can't work out who to contact.
Thanks,
Jon
02 Apr 2024 04:06 PM
Posted by a Superuser, not a Sky employee. Find out moreCall 150 from your Sky landline or the 03 number at the bottom of https://sky.com/help
When on the phone just state your problem as a broadband technical issue then hold through any prompts to go online or get a text
02 Apr 2024 02:32 PM
Posted by a Superuser, not a Sky employee. Find out more@JonL12345
Please post your router stats
02 Apr 2024 02:38 PM
02 Apr 2024 03:15 PM
Posted by a Superuser, not a Sky employee. Find out moreYeah there is still a line fault that needs fixing, afraid you'll need to call Sky again and get it reported
02 Apr 2024 03:57 PM
The problem is I cannot work out how to speak to Sky. I am going round in circiles with their Sky Virtual Assistant. And the online internet service checker says my broadband is fine.
02 Apr 2024 04:10 PM
Ok, thank you for that.
11 Apr 2024 11:29 AM
Did you get the problem fixed? I have an intermittant issue - which bascially meas I cant work from home as video calls drop every 5 - 10 minutes. I spoke to an agent they rant a test and said it all looks fine so they wouldn't contact OpenReach. I kept saying its intermittent - had to beg for them to get an engineer out (again). I'm thinking of ditching sky brodband and maybe getting a 5G router?
11 Apr 2024 07:13 PM
I had an Open Reach engineer come out 3 times. Today, he changed a cable from my house to the pole over the road. Speed seems normal and no dropouts yet today.
I installed a Chrome extension called Internet Connection Monitor. It helps you by giving a graph showing when dropouts occur, uptime etc.
24 Apr 2024 09:39 PM
Mine is doing the same thing!
I barely get 4G at my house, some times I get E so I don't think I can go down the 5G router 🤣
