06 May 2022 11:55 AM
I have switched broadband provider to Sky and WhatsApp is not working. It won't connect and I get a message telling me I have no internet connection, however every other app is working, and there is no issue with my broadband. Other people with an iPhone can't connect using my broadband but android users can. Any ideas?
06 May 2022 01:34 PM
Posted by a Superuser, not a Sky employee. Find out moreHave you checked your Sky Broadband Shield settings:
https://broadbandshield.sky.com/
06 May 2022 03:03 PM
Yes, I have
05 Jun 2022 07:52 PM
Mine was doing the same as I've just switched to sky broadband too. I had to change shield settings. It was set to block most things. Which is good in one way but fairly annoying in another. As WhatsApp is so widely used. Why block the most common app in the world. Sorted now. Check your shield settings.
06 Jun 2022 10:45 AM
@Cwmynys wrote:Yes, I have
06 Jun 2022 07:30 PM
I modified shield settings for it to work with WhatsApp. Solved it for me. Thanks for reply.
24 May 2023 10:28 AM
Same problem how did you solve it
24 May 2023 10:34 AM
Posted by a Superuser, not a Sky employee. Find out more@Pauline++c normally caused by the default setting for Sky Broadband Shield which you can change by using the My Sky app under Broadband settings.
02 Feb 2024 11:43 AM
Thank you so much much I have changed the shield and now I can work on my phone at home.
