26 Jul 2023 04:03 PM
Although I have unlimited broadband data, I would be interested to know how much data I have used each month but do not know how to find this out.
Can anyone help please?
27 Jul 2023 09:51 AM
Posted by a Superuser, not a Sky employee. Find out moreI've found that sometimes the data usage doesnt appear, probably due to Sky's backend systems. Since all their packages are now unlimited its a pretty non-important bit of telemetry for the Sky app itself.
26 Jul 2023 04:11 PM
Posted by a Superuser, not a Sky employee. Find out more@Rich+111 Used to be able to check when doing a broadband test it would tell you the data that you have used during the last months and so far what you have used in that given month.
26 Jul 2023 04:15 PM
I did a test but it doesn't appear to show how much data used.
26 Jul 2023 04:17 PM
Posted by a Superuser, not a Sky employee. Find out more@Rich+111 Once the test completes you should be able to scroll down and see that information. I don't have broadband with Sky now, so unable to tell you if this is still the case.
26 Jul 2023 05:41 PM
Posted by a Superuser, not a Sky employee. Find out more@Rich+111 & @Highlinder you can get to see usage by using the Connection test in the My Sky app and choosing to test your wifi. When that completes you get your monthly data usage then click on the figure and you getvthe graph below
26 Jul 2023 06:25 PM
Posted by a Superuser, not a Sky employee. Find out more@Chrisee I was sure it was around that area. Not having Sky broadband now I am just going off memory when it comes to small things like this.
26 Jul 2023 06:26 PM
Posted by a Superuser, not a Sky employee. Find out more26 Jul 2023 06:30 PM
Thanks for your replies. I've done the tests but it just gives me the speeds that have been achieved and not the data usage.
14 Jan 2024 11:55 AM
I could not find out how much data I have used ? Has anyone been able to find out ? Thank you.
14 Jan 2024 01:01 PM
Posted by a Superuser, not a Sky employee. Find out more@jrh2254 Others have been able to find it via runnning the broadband test. Just scroll down to see this and it should be there for you to find.
