15 Mar 2024 05:53 PM
15 Mar 2024 06:01 PM
It depends on the type or router you currently have and the type of service at the new address
the old q routers are getting replaced with a newer model that supports VoIP
Do you know what type of service was ordered?
15 Mar 2024 06:03 PM
What hub do you have now er115 q hub or sr203 broadband?
From last september last year all new connections require the sr203 so the the telephone is plugged into the back of the router ie internet calls instead of a mastersocket
15 Mar 2024 06:20 PM
Looks like we have the Sr203 router
19 Mar 2024 11:56 AM
Posted by a Superuser, not a Sky employee. Find out moreYes you take your router with you, so just plug it in when you move, no need to do it beforehand.
