26 Sep 2023 02:59 PM
Basically had this problem on my other xbox last January Basically unplayable despite me having 70 mb line speed,,, and using a ethernet cable directly to the router,,z I sold that xbox have spent next to £200 on new xbox and fifa game for it to he unplayable,,, here's my router statistics
26 Sep 2023 03:24 PM
Posted by a Superuser, not a Sky employee. Find out moreYour router stats suggest there is no ethernet cable in use. Are you sure its connected properly?
26 Sep 2023 03:30 PM
Yes its plugged into my xbox and to my router in port one I'll do it again now because like an idiot didn't have my xbox on shall I do router stats again with xbox on. Sorry
26 Sep 2023 03:33 PM
26 Sep 2023 03:34 PM
26 Sep 2023 03:37 PM
I am using a 20 Meter adsl cable as not in the room I'm originally in with rhe adsl port is ,,, I'm upstairs in different room will that make a difference
26 Sep 2023 03:43 PM
Posted by a Superuser, not a Sky employee. Find out moreYou say ADSL cable, do you mean ethernet/RJ45 cable? Or do you mean your using an extended ADSL cable to move the router closer to the Xbox?
26 Sep 2023 03:47 PM
Extended adsl cable,,, and using ethernet cable from router to xbox
26 Sep 2023 03:50 PM
Posted by a Superuser, not a Sky employee. Find out more@Treblered99 your hub is synching at 80Mb/s down and 20Mb/s up so the long cable to the master socket doesnt look to be causing issues. There is nothing obvious in the stats showing a line issue and assuming the ethernet cable is direct and not via powerline/ switches etc then that can be ruled out.
There can be issues with Sky hubs if there are multiple simultaenous users as the hub like other freebie routers does not have any way of prioritising game traffic so a couple of others in the household watching different video streams could cause issues. If that applies you may need a more powerful router optimised for gaming. You can set up,a Broadband Quality monitor see https://www.thinkbroadband.com/broadband/monitoring/quality that will show if there is an issue between your hub and the main London Internet Exchange which is rare but possible..
However there is one other possibility which comes around every year when EA Games launch their annual update which is simply their servers can't cope. If that applies other non EA Games games should play smoothly.
26 Sep 2023 03:53 PM
Posted by a Superuser, not a Sky employee. Find out moreAh okay, not the ADSL cable shouldn't be causing as issue because your sync looks fine. However it could be that the extended cable is causing line errors in the background that the router isnt showing. These errors can quite easily cause packet loss so could you try with a normal length ADSL cable?
28 Sep 2023 06:39 AM
Hello I'm back again I signed upto that broadband quality manager after I thought my Internet sorted it self out from 12- 4pm and could play and and enjoy online gaming,,then it when back to previously poor connection,,,, here's my bqm graph when you compare it to there for problems mine deffo not ok and its not comparable to theres examples,,,, can you explain to me if this chart to me
28 Sep 2023 07:28 AM
Posted by a Superuser, not a Sky employee. Find out more@Treblered99 red iss bad as the connection is lost, but as @jamesn123 points out the long ADSL cable could be a factor. I would temporarily move the hub back to a couple of meters from the master socket using a standard DSL cable to see if thst sorts the issue. If it does then there's the problem if it doesnt there are issues with the line.
