28 Sep 2022 09:21 AM
Trying to set up Firewall on Sky Q router. Under IPv4 settings I want to block Any (all) but the option is not there. I have blocked one IP address already and was able to pick Any (all). I have no knowledge about this sort of stuff, relying on Google.
28 Sep 2022 02:17 PM
Posted by a Superuser, not a Sky employee. Find out moreCan you explain what exactly your intended goal here is? From what you are describing it sounds like you are just attempting to block all IPv4 connections which is going to render your broadband useless.
28 Sep 2022 02:45 PM
Thanks, @jamesn123, for your reply. I"m trying to block 2/3 specific devices using their IP addresses.
28 Sep 2022 02:53 PM
Posted by a Superuser, not a Sky employee. Find out moreI dont believe the Sky hub can facilitate what you are trying to do. If you wish to block a specific domain/IP you may be better doing it on your Sky Shield account instead.
28 Sep 2022 03:10 PM
27 Dec 2023 12:41 PM
Did you manage to set the firewall access in the end? I am having issues with doing this on our new hub?
Thank you @nbb27
