15 Nov 2023 11:53 AM
Anyone else's SR203 showing their connection speeds in the router stats?
Don't think there has been a firmware update, but connection did drop in the early hours and now it shows what I'm connected at rather than 0kbps.
15 Nov 2023 11:56 AM
That happened recently however others on fttp are querying whether they are the line stats or just harvested from the profile
15 Nov 2023 12:04 PM
Thanks @cookiemonsteruk - fair point. Are the figures accurate or just filling a box?!
Shall have to keep any eye on them.
Been getting the orange voice light, necessitating a unplug of the router for a few mins so was thinking if it was a firmware upgrade it might help with that!
15 Nov 2023 12:18 PM
We are waiting for word back from community managers on the accuracy ie will it show a fault when there is one.
15 Nov 2023 12:22 PM
That would be good. I hear it's Sky servers without enough addresses causing the orange voice light issue. Bit frustrating as I upgraded to FTTP for more stability!
15 Nov 2023 12:30 PM
The orange voice light has been an issue since sky rolled out fttp and tends to bring down the broadband as well without an underlying broadband issue. Again whether or not the stats you posted will revert to zero would provide a clue as to where those downstream figures are gleaned from
15 Nov 2023 12:33 PM
Assuming it lets me log into the router. Sometimes it has when the connection is down, sometimes it hasn't! 🙄
15 Nov 2023 01:44 PM
I found it strange that it never showed. Must be maxed out at 999.9mbps, sometimes the speedtest.net gets to 1.2gbps 🙂
