Discussion topic: Deco Double Nat and Xbox
This message was authored by Moycullenmugs This message was authored by: Moycullenmugs
Hi there and apologies if this is an old issue.
My son plays on his Xbox until all hours. Because Sky broadband didn't offer any parental control (in Ireland) I purchased a Deco mesh system with parental control so I could cut off the Xbox at bed time.
But now he's getting a double Nat message and it's limiting his engagement with buddies on line.
Is there anything I can do to solve the Double Nat but maintain control
Thank you
This message was authored by mae-3 This message was authored by: mae-3
Re: Deco Double Nat and Xbox
@Moycullenmugs
You could try forwarding the Xbox port through both the Sky Hub and Deco to the Xbox, eg: the usual default port is 3074.
Zen internet on G.fast (250Mbps down, 50Mbps up). SAT> IP (Apple 4K 2nd gen TV to LG C1 OLED UHD TV/Dolby Atmos Denon AVR, DacMagic Plus for Hi-Res audio), hosting own blog/forum (cluster), OPNsense & Zenarmor L4/L7 NGFW & DPI IDS/IPS, Asus ET12 Pro Tri-Band wifi, Linux, Gamer: Xbox Series X/i7 laptop, round-robin DNS over HTTPS, non-proprietary VoIP HD AMR-WB (G.722.2) and more... Beta tester Apple iOS/watchOS/tvOS/iPadOS/macOS.
