14 Jan 2024 06:31 PM
hi I am hoping that someone can help me with a very confusing situation I am experiencing.
I have ben a sky customer for many years but recently decided to switch broadband to a fibre provider. It was installed a few days ago, The installer showed me speeds I was getting at my new hub via his IPad, Wired 950Mb's - Wireless 400Mb/s.
I connected my new router directly to my Sky Q box via Ethernet cat 5e cable and reset my network for a wired connection. When it connected it did so via a random network name which I have never seen before and dont recognise. I did a speed check via the Netflix speed checker and got 400Mb/s. A few minutes later my network name changed back to the name of my new router - speed test still showed 400Mb/s. I pulled the cable out of the Sky Q box - the network dropped out and then came back on with a speed of around 95Mb/s. I reset my network and joined via wireless - speed still 95Mb/s. I reinserted the ethernet cable into Sky Q and wireless speed more or less immediately went to 400Mb/s. I repeated this a few times with the same result. I suspect that thre 400Mb;s speed I get is wireless not ethernet but I dont understanwd if that is so why the network drops out when I remove the ethernet cable. Can anyone help.
14 Jan 2024 08:37 PM
Not entirely clear what you are asking, but you may well see faster speed on a Q box using WiFi rather than ethernet because some models only have 100Mbs ethernet chipset, plus 802.11ac wireless. Given UHD streaming tops out at around 30Mbs, a Q box doesn't benefit from anything more: they aren't designed for multiple simultaneous downloads.
