Discussion topic: Broadband signal loss
This message was authored by BrianSautereau This message was authored by: BrianSautereau
Intermittent fault with broadband connections. Also very weak Wi-Fi signal
Re: Broadband signal loss
@BrianSautereau Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
