Discussion topic: Broadband not working
This message was authored by Robbi This message was authored by: Robbi
Got a new Sky Broadband Hub sent. Activation date was yesterday (Friday 15th March) and still nothing is working. Below is what the sky hub is showing and the socket we have.
What am I doing wrong?
Re: Broadband not working
@Robbi
Your mastersocket only has a telephone port with a cable for the telephone. It should have a microfilter/broadband splitter with 2 ports one for broadband and one for the landline.
Are you new to sky? Has that setup worked previously?
@Robbi
"Activation date was yesterday (Friday 15th March"
Also note the the telephone itself plugs directly into the sky hub
This message was authored by peter-marlow+1966 This message was authored by: peter-marlow+1966
You have not and unless you  have a splitter  to plug  in there first one side for  the Internet  cable  to the router and the other side  for the telephone, you only  have  the  telephone  line plugged  in at the  moment that's  why you have no Internet
There should  be  a splitter  on the box the router  come in. it's  white and plugs in the socket  first
Robbi
There is no splitter / sub filter sent with the sky box. First time using this set up as we have only just moved in. Can I purchase a splitter and expect it to work?
@Robbi
Heres one from b&q
https://www.diy.com/departments/slx-2-way-adsl-splitter/5028422001776_BQ.prd
But try argos, currys, pc world etc
@Robbi
By the way did you get the dsl cable which has purple identical plugs at both ends
Robbi
I got one grey cable, one black cable, each with one purple end .
@Robbi
You would need a dsl rj11 to rj11 cable with identical purple plugs at each end
Heres one from argos but try the usual electric stores
https://www.argos.co.uk/product/4039871
Robbi
And If i get the modem wire which part do I plug in where?
@Robbi
Once a microfilter is installed it will give you a broadband port and telephone port . One end is plugged into the broadband port on the microfilter the other end will plug into the purple dsl port on the sky hub
Robbi
Is that not what the black/ grey cable is for ?
@Robbi
I thought you said you had 2 cables each with 1 purple plug . If you have a cable with a purple plug at each end then that is the dsl rj11 to rj11 cable and you just need the microfilter as show above in the b&q link
This message was authored by JimM1 This message was authored by: JimM1
@Robbi Here is the online manual, select when you get to the point, no i dont have internet calls. will show you the description, and you may have the dsl filter in the box, depends if sky included or not, some have and some dont.
Set up your Sky hub | Sky Help | Sky.com
