Discussion topic: Broadband needs resetting several times a day. Sky online Chech states no problem
This message was authored by Liz76 This message was authored by: Liz76
No WiFi several times a day. Broadband check on line states all fine. Reset procedure does not resolve problem
Re: Broadband needs resetting several times a day. Sky online Chech states no problem
@Liz76  When you have no Wi-Fi can you run the test in the link below.
Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
