Discussion topic: Broadband keeps dropping
This message was authored by Callyjack This message was authored by: Callyjack
Over last few days broadband keeps dropping out and the takes a while to reconnect, the orange internet light flashes and voice light is orange?
Re: Broadband keeps dropping
@Callyjack run the connection test in the My Sky app when the hub is connected to see if Sky are aware of an issue. If they aren't you need to report the fault by giving them a ring.
If you would like advice from the forum post your hub's ststs as explained here Find your Sky Broadband router statistics
