Discussion topic: Admin and password
This message was authored by Ilario This message was authored by: Ilario
Admin and password
I can't sign in into my router sky
Re: Admin and password
@Ilario
Are you trying to connect to the WiFi network or login to the admin portal of the hub?
I am NOT a Sky Employee
Ilario
Admin portal
Username: admin
Password: Your default WiFi password printed on the hubs sticker.
Ilario
I have tried that one but without success
@Ilario
Are you sure you are typing all the characters correctly? e.g. capitals & lowecases correct.
Also if your using an Apple device try another device as Apple + Safari often has issues logging into the admin interface.
Ilario
 My wi-fi keeps on disconnecting.
@Ilario
Your stats show that the line dropped approx 1hr50mins before you took the screenshot. How often does this happen?
Have you run the line test in the My Sky app?
Ilario
Yes I did it
