Discussion topic: Tnt
This message was authored by: Slim3
Tnt
TNT sports not working , saying no signal .
enery other  channels working fine
Re: Tnt
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please note: Free (advert supported) Hayu content is available via the On Demand section of your Sky planner, you DO NOT access the free content via the Hayu app!
Re: Tnt
@Slim3
Do you have Sky Q ?
