Discussion topic: Technical fault on recordings
This message was authored by: Fred98
Message posted on 07 Dec 2025 02:39 PM
Recordings message there is a technical fault
Find out more
Message posted on 07 Dec 2025 03:32 PM
Re: Technical fault on recordings
You have posted in the Sky Go forum that does not have recordings
Please answer the following question so that your thread can be moved to the correct place, where you're more likely to get help with your query
Which Sky TV Service do you have?
- Sky+ (Satellite box)
- Sky Q (Satellite box)
