6
This discussion topic has been answered Discussion topic: TNT Sports not working
This message was authored by: Paddy661
My TNT sports channels are not working but every other channel is. Any ideas?
This message was authored by: lettice Answer
Re: TNT Sports not working
Which Sky box do you have Sky+ or Sky Q.
If it's Sky Q, work through the advice given in the article linked below, where you can use an online form in the article to book a Sky engineer to check/realign your dish.
If it's Sky +, follow the advice given in this post (post3) on a previous thread;
https://helpforum.sky.com/t5/Sky/No-satellite-signal/m-p/4909057#M156255
By "not working" what is actually happening ?
Avatar for Paddy661
The message comes up on TNT sports channels
This channel is currently affected by a problem with your satellite signal
Not sure what Sky box you have, Sky Q or Sky +
But, try a power restart of your Sky box and see if that helps.
Avatar for Paddy661
Tried all that, it's just the TNT sports channels
Sounds like your dish may be misaligned slightly
