Discussion topic: Sky Sports TV guide
Message posted on 12 Nov 2023 10:48 AM
Sky Sports TV guide
Hi,
Does anyone know what's happened to the Sky Sports TV guide? It used to show what was on each of the channels throughout the day, but has diappeared completely in the last few days. I started having to edit the bookmark to change the date every day, but even that no longer works. This url used to take you to the full guide, https://www.skysports.com/watch/tv-guide/12-11-2023 but now it just takes you to a whats on now page. Quite infuriating
Message posted on 12 Nov 2023 11:59 AM
Re: Sky Sports TV guide
It appears they have changed it so there doesn't appear to be anyway to go back to the previous version as you are not the first and will not be that last to comment on this.
Message posted on 12 Nov 2023 12:15 PM
Does the 'live on Sky' link section on the Sky Sports site that I have been using for years, not provide what you are looking for?
All the live sport across the Sky Sports channels as All sports or by selecting individual Sports.
https://www.skysports.com/watch/sport-on-sky
Message posted on 12 Nov 2023 12:22 PM
Thanks, but not really. The guide which has gone showed a list of channels and what was on at what time in a grid formation. It also showed what was on over the next 7 days, so it was easy to plan your viewing. As usual when something is easy and works well, Sky change it without any notice..
Message posted on 12 Nov 2023 12:26 PM
Was it something like this one.
You have to select Sports via the first selection, next to region;
https://www.sky.com/tv-guide/20231112/4101-1/
Message posted on 12 Nov 2023 12:46 PM
Yes it was, but it only showed Sky's own sports channels. BT or should I say TNT sports have done exactly the same with their TV guide, changed it, made it less user friendly. Have these people not heard the old adage 'if it ain't broke don't try and fix it' 🤔
Message posted on 21 Nov 2023 12:24 PM
Its frustrating I used to do the same thing with the Grand Prix. I would check a few days before and work out when I was going to watch the programmes for the weekend. And if I missed the live shows catch up with the highlights. It was great but now it's disappeared. Showing what's on now is no help
Message posted on 09 Dec 2024 06:55 PM
What about non-live programmes? Presumably Sky don't want those watched
