Discussion topic: Remote does it connect
This message was authored by: Corinne57
Message posted on 19 Jun 2026 10:05 PM
Can't get remote to access Sky
Find out more
Message posted on 20 Jun 2026 12:04 AM
Re: Remote does it connect
@Corinne57 Which Sky TV service do you have? Sky+HD, Sky Q or Sky Stream?
This message was authored by: Marlu-Nyu
Sky Q (with Sky Cinema & Sky HD) • Sky Broadband (Fibre) • Sky Talk (VoIP)
Disney+ • Paramount+ • HBO Max • Discovery+
Message posted on 22 Jun 2026 01:33 PM - last edited: 22 Jun 2026 01:34 PM
@Corinne57 wrote:Can't get remote to access Sky
To connect your remote to your device using its Bluetooth:
Sky Q:
- Switch on the Sky Q box and television.
- Point the remote towards the Sky Q box.
- Press and hold 1 and 3 together until the remote's light flashes.
- Follow the instructions displayed on the television.
Sky Glass:
- Switch on the Sky Glass television and display the Home screen.
- For a new remote, remove the battery tab.
- Press and hold 1 and 3 together for three seconds.
- Wait for “Your remote is now connected”, then select Continue.
Sky Stream:
- Switch on the television and Sky Stream puck, with the Sky Home screen visible.
- Switch off any nearby Sky Q box so the remote does not attempt to pair with it.
- Hold 1 and 3 together for three seconds.
- Select Continue when the connected message appears.
If that is not working, try resetting the remote first:
Press 7 and 9 for three seconds.
