Discussion topic: Pin Removal from Paramount plus
This message was authored by: Commoner
Can anyone help me with the process to remove the pin from paramount plus account.. it says go to app where you subscribed... thanks
Re: Pin Removal from Paramount plus
hi @Commoner
If you can login via a browser you should be able to reset the Parental controls from the Account section there
