Discussion topic: No satellite signal
This message was authored by: PH44
No satellite signal
No signal for over a day. App says there are no service issues.
This message was authored by: Newmanbj
Re: No satellite signal
Still cannot either sky boxes to the internet, even though router lights are all green
@PH44 @Newmanbj
Do you have Sky Q, as your broadband connection has nothing to do with a satellite signal issue.
"No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
