Discussion topic: It won’t accept my pin
This message was authored by: Babs47
It won't accept my pin
Re: It won’t accept my pin
@Babs47  Based on the minimal info the community won't be able to help, you will need to provide much more info.
What are you trying to input your pin into?
This message was authored by: Marlu-Nyu
Is this the PIN you enter on your remote, for buying Sky Sports Box Office, or watching 12, 15 or 18 rated programmes before 9pm? If so, you can reset it:
Sky Q:
  1. Press the Home button on your Sky remote.
  2. Scroll to the very bottom and select My Sky
  3. On the second row, select "Reset PIN".
  4. Follow the on-screen prompts to set your new PIN.
Sky Glass/Stream:
  2. Scroll to Settings and press Select
  3. Scroll to Parental and press Select
  4. Scroll to PIN and press Select
  5. Select "Forgot PIN"
  6. Follow the on-screen prompts to set your new PIN.
