Discussion topic: Humax connection with Sky dish
Message posted on 31 Jul 2025 04:41 PM
My Humax box is not receiving signals from my Sky Dish which has a wide band LNB do I need to change the dish ??
Message posted on 31 Jul 2025 04:54 PM
							Re: Humax connection with Sky dish
Is your Humax a 4k or HD box? Some wide-band LNBs have fixed outputs, typically 2 UHD and 4 HD, so your Humax would need to be connected to the right pair.
Message posted on 31 Jul 2025 04:55 PM
@Steve160656 wrote:My Humax box is not receiving signals from my Sky Dish which has a wide band LNB do I need to change the dish ??
If you have switched from Sky Q to Freesat using a Humax box then you'll need to change the wideband LNB on the dish to a standard narrowband LNB, or upgrade your Humax box to a newer Arris Freesat 4K box which is compatible with the Sky Q wideband LNB.
Message posted on 31 Jul 2025 06:15 PM
Hi
Its a HDR1100S so just HD ... The LNB is a wideband with 2 cables
Message posted on 31 Jul 2025 06:18 PM
Hi,
Thanks for that , what I have read suggests I need a wideband LNB , which is what is on the dish anyway.
Guess changing to a narrowband LNB would be the easier option , cheers
Message posted on 31 Jul 2025 06:36 PM
@Steve160656 wrote:
Hi,
hi @Steve160656
You may have already found this out but the older LNBs used by your box and many other receivers are known as Universal LNBs.
BTW Technically they send approx 1/4 of the signal at any one time depending on the voltage & the presence or not of a 22KHz signal to provide Hi/low Bands & H/V polarisation (The wideband LNBs as per their name send both the High & Low Bands in one 'wide' band and use 2 cables - one for each polarisation)
