Discussion topic: Sky Max router telephone connection
Message posted on 06 Jun 2026 05:41 PM
There are three ports on the back of my Sky Max router - one unlabelled, one is standard UK phone socket and one is labelled Italia/ROI. My landline telephone plug fits the Italia/ROI socket, and I get a dialling tone when plugged in. But when I try to dial out no connection is made.
do I need a converter from the plug on my phone to make it a standard UK plug, or should the Italia/ROI socket work?
Message posted on 06 Jun 2026 06:01 PM - last edited: 06 Jun 2026 06:01 PM
Re: Sky Max router telephone connection
@NickShepherd999 previous posts suggest the ROI/Italia and UK sockets are wired the same - it's just the connectors that are different, so I dont think you'll need a converter.
When was your Sky service activated? It can take a day or so for the phone service activation to complete, particularly with the Max Hub.
Message posted on 06 Jun 2026 06:20 PM
Thanks. We have had the service some weeks now - I am just getting round to plugging in the phone as not used much.
So I do find it a bit odd - especially as I get a dialling tone.
Message posted on 06 Jun 2026 07:02 PM
@NickShepherd999 when it's convenient try switching off your Hub (and the ONT if you have full fibre) at the plug for an hour. If it's still the same afterwards, it's probably best reported to Sky.
We can ask Sky's messaging team to contact you here so that you can report it via a private online chat, if you wish.
