Discussion topic: No voice light on WiFi box
Message posted on 24 Dec 2024 01:44 PM
All other lights green, voice light no light at all: unplugged, reset, nothing happening? What else can I try? before kids get bored with socialising 😢
Message posted on 24 Dec 2024 01:46 PM
							Re: No voice light on WiFi box
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Message posted on 24 Dec 2024 01:48 PM
@Emmy98 are you new to Sky Talk (landline)? Or has your Sky landline been working ok up to now? Is your phone plugged into your broadband Hub?
Hi thanks for your reply, ran the test all says good, no issues showing with hub, connection etc, it shows no devices connected, but yet when I try to connect it says no internet connection.
Message posted on 24 Dec 2024 01:50 PM
No been with sky for a long time, just came down this morning to no internet on tv, we've lost connection before but it's always come back on within 5 mins or so, I've asked others on the street and they have no issues.
Message posted on 24 Dec 2024 01:52 PM
Oh sorry yes the phone cable is in the router like the last engineer recommended when he changed the internal socket 18 or so months ago.
Message posted on 24 Dec 2024 01:55 PM
Have you tried a reboot of the hub at the mains then after powering it back up waited for 5 minutes to see what then happens ?
Message posted on 24 Dec 2024 01:58 PM
I've given everything I can think off a go, disconnected all cables/connections for like half hour, factory reset which then in turn took away the amber light which was on the voice bit to no light at all.
Message posted on 25 Dec 2024 11:10 AM
Back up and running by the afternoon, was a fault on the phone exchange, but did managed a game of monopoly with the kids before returning to their gaming.
