Discussion topic: Loud crackling and buzzing noise on all calls
This message was authored by: Bramlyn45
My landline is making a loud crackling and buzzing noise at my end whenever I receive or make any calls. The noise is so loud I can't hear what the other person is saying but they don't appear to be able to hear it at their end of the line.
Re: Loud crackling and buzzing noise on all calls
Try the simple connection test here, even if your broadband seems ok: https://www.sky.com/help/articles/broadband-diagnostic-start
@Bramlyn45
Have you another means of reporting this to Sky (ie; your mobile)? Sky can check the line and forward any fault to Openreach to investigate.
Avatar for Bramlyn45
Level 0 icon
Thanks, I've tried running that but it says no errors were found
