Discussion topic: Landline problems after moving from Sky
Message posted on 29 Apr 2024 12:59 PM
I wondered if anyone has experienced a similar problem to me.
I moved from Sky broadband and talk last year and since then it appears that Sky or NOW cunstomers are unable to call our landline from their landline, they get a message saying that the number is not recognised. This problem does not exist for anyone not with Sky or NOW, they can all call us perfectly well.
Sky advisor said it is not a Sky problem but BT.
Message posted on 29 Apr 2024 01:03 PM
Re: Landline problems after moving from Sky
Have you reported this to Customer Services of your new provider?
Message posted on 29 Apr 2024 01:15 PM
Hi, yes I have reported it and they are trying to sort it but asked me to contact Sky.
i have since found out that this is not an uncommon problem and is caused by the number not being correctly ported from Sky.
Message posted on 29 Apr 2024 01:21 PM
I doubt Sky will be able to help as you're no longer their customer. If that's the case, those who can't call you should report it to their provider.
Message posted on 29 Apr 2024 01:36 PM
And therein lays the problem. They have reported it and are told that we must be blocking number, which we definitely aren't.
We are now trying to find out where the buck stops.
Message posted on 29 Apr 2024 01:40 PM
By all means give Sky a try.....
