Discussion topic: External Calls Not Working Since Full Fibre Installed
This message was authored by: JOHNN26
I have now moved over to full fibre broadband this morning.
I can dial out on the landline, but we are not receiving external calls.
Phone is plugged into router.
How long does it take for external calls to work?
Re: External Calls Not Working Since Full Fibre Installed
@JOHNN26
It's normal for the Sky Talk landline to not operate fully for 24+ hours after the broadband activation. Presumably you've got it plugged into the back of the hub and NOT a wall socket?
Avatar for JOHNN26
Level 3 icon
@Daniel0210
Thanks. Yes plugged into router.
Avatar for JOHNN26
Level 3 icon
Still the same situation today, still not receiving any incoming calls.
@JOHNN26
I suggest giving it til mid afternoon. It not working fully by then report it to Sky by dialling 150 from your landline.
@JOHNN26 do you have a black broadband Hub, or white?
Avatar for JOHNN26
Level 3 icon
@Mark39  it's the black hub. Thanks
@JOHNN26 you could try turning off both your Hub and ONT off at the plug for 10 minutes. If that doesn't resolve it, it may simply be taking a bit longer for activation to complete. It's fairly commonly reported here - in my case it recently took 3 days to move from the copper-based landline service to Hub. You could give Sky a call, as @Daniel0210 posted, or avoid the hassle and wait for a few more days to see if it sorts itself out.
