Discussion topic: skybox not working
Message posted on 03 Jul 2025 02:30 PM
skybox not working
prompt message sky not getting satellite signal I have plugged it out restart several times and it's the same
Message posted on 03 Jul 2025 02:36 PM
Re: skybox not working
I need to speak to someone as my skybox is not working. I have plugged it out and restart several times but it remains the same
Message posted on 03 Jul 2025 02:38 PM
@Anonymous The cause is most likely a fault with your dish or cables. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
