Discussion topic: sky pin problem
This message was authored by: Martyn57
sky pin problem
Responding to a sky offer for UHD and requested my pin. Tried 3 times, wouldn't accept pin so followed instructions to change pin.
Then says pin changed succesfully but when going back to order the upgrade says pin incorrect chsge pin....
This keeps looping and no apparent solution?
Any help would be appreciated.
Re: sky pin problem
@Martyn57
Sky+ (where you've posted) is not compatible with UHD so which TV service do you have?
