3
This discussion topic has been answered Discussion topic: sky box has stopped working
This message was authored by: tesco14
I can get sky on the screen, but it's a straight link to whatever the normal tv is  set on, and it shows a still photo/picture on about 1/4 of  top half of L/H side of screen, but in two boxes? then it just a series of coloured lines across the screen to the right from what's picture is showing on the left. only the on and off button work> I have turned everything off at the wall to give chnace for reset but stays the same> The normal tv works as normal> Bottom half of the screen all along is nothing. I did remove veiwing card and that had a bit of a burn mark thought to the other side so don't know if that's failed> thank you
Avatar for tesco14
This message was authored by: tesco14 Answer
Re: sky box has stopped working
I do have an older box(worked), but I had an email a week ago about free upgrade to sky Q, so I think that's come at the right time> Thank you both  for your help
Please Note: Sky+ is now a legacy service that Sky are winding down
You could try to force a software update (see my Sky Plus FAQ), that does sounds like a busted box with a hardware fault 😞
I agree with @Annie+UK - sounds terminal to me. It's unlikely to be anything to do with the Viewing Card - the discolouration is normal. You can pick up a used replacement Sky+HD box from ebay etc . Just look for a DRX890 or DRX895 as they're the most recent.
Alternatively, you could upgrade to Sky Q.
Avatar for tesco14
