Discussion topic: satellite codes
This message was authored by: MarkDickinson
satellite codes
hello - i have an old sky box and once a week / fortnight - you need to send the magic codes so that my sky sports works. it has gone off again. can you please send the codes. it then works again. thank you
Re: satellite codes
@MarkDickinson  Your duplicate thread in the accessibility forum has been removed s you already raised the same question in this section (and it's not a accessibility services related issue).
Re: satellite codes
@MarkDickinson
We are customers who help each other so I'm not sure what you mean by "magic codes", so as this is something Sky need to do then you will have to do as you have done before presumably and that is the call them.
