Discussion topic: no satellite signel
This message was authored by: cazz59
no satellite signel
box not receiving signel , checked wires,router,and working on my tablet
Re: no satellite signel
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
