Discussion topic: issue with sky box
This message was authored by: sm_ldn
issue with sky box
my sky box has everything green but there's no signal coming up on the device is there a fix for this?
Re: issue with sky box
@sm_ldn
No signal or no satellite signal? They are totally different.
Avatar for sm_ldn
Level 0 icon
this doesn't help- its not connecting to the devices when it previously was
@sm_ldn
What error message is showing on the screen?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
Do you mean TV screen? Seems an odd way to phrase it.
