Discussion topic: how do i get a replacement sky handset
This message was authored by: Michael566
My Sky handset is broken how do I replace it?
Re: how do i get a replacement sky handset
Cheapest way is to buy one from your local supermarket or hardware store. Otherwise you could try onl8ne, or at Sky's Accessories store.
https://www.sky.com/shop/accessories/
You purchase one either from a local store or online
I am NeurodivergentMy Sky FAQs: Stream Glass Go Plus
This message was authored by: Saxonanglo
I have seen apps on my iPhone which  say that they can be used as a remote control for Sky.
I have also seen remote controls to buy on eBay
