Discussion topic: card entitlements on SD boxes
This message was authored by: HeathHayle
now HD boxes had to registered on my account now been thinking about using my SD boxes with the remaining non premium channels that havent moved to DVB2 yet but was wondering will the viewing card still get entitlements while in the SD box or are entitlements only send to viewing cards that are matched to a box also while the viewing card is in a SD box could a repairing try and happen using the satellite dish while the viewing card is in the SD box messing up my account
= Sky+ SD boxes x4 (pace bskyb 3100) ===
Re: card entitlements on SD boxes
Sky+ Viewing cards are locked to the box they were in at the end of October 2024 and they cannot be used in any other box
I am NeurodivergentMy Sky FAQs: Stream Glass Go Plus
Avatar for HeathHayle
Level 6 icon
yes sorry I know that but I remember I put my card in a SD box once and some of the channels worked without pairing the card
@HeathHayle give it another try?
Level 6 icon
yes I just dont want it to try and repair using the satellite dish and mess up my account
@HeathHayle
As cards can no longer be paired with other boxes, personally, I wouldn't risk moving a card to another box
Level 6 icon
thats what I was thinking not worth the risk thanks guys as always
Level 6 icon
about the card entitlements will I receive them if my box is on standby on nickelodeon +1 channel
Level 6 icon
I mean on the box the viewing card is paired to
@HeathHayle so far as I'm aware the Viewing Card is updated over the air whether the box is in standby or switched on.
